RFQ - Hard to find Electronics/Hardware
Military parts and aviation
Postby rksnow69 on Tue Mar 12, 2013 8:12 am
Looking for vendors to submit RFQ for the attached list. All parts must be at least NS with your COC's. Due to business contracts, can only deal with U.S. vendors. Need response on any items by 22 March, 2013. Please respond to keith.snow@kratosdefense.com
Part Number NSN ITEM NAME QTY
010-0050-924-617 5340123127863 SEAT, BALL SOCKET 15
100-773-21 5930009105331 PRESSURE SWITCH 13
10043754-19 1430010644461 SHELL CORE ASSEMBLY 3
10043754-20 1430010644460 CENTER CONDUCTOR 1
10043943-126 5945008890806 RELAY, ELECTROMAGNET 3
10043943-276 3110001336731 BEARING 45
10044085 5960008349107 ELECTRON TUBE 47
10046468 1430009022752 HOUSING LIQUID COOLER 1
10067948-22 5977009237127 BRUSH HOLDER 5
10068320 3110008656921 BEARING, BALL ANNULAR 1
10103653 7230009971488 CURTAIN, BLACKOUT 1
10105654 6105009728061 MOTOR,DIRECT CURRENT 3
10105961-1 5945009608234 RELAY, ELECTROMAGNETIC 11
10105990 4130009956657 FILTER ELEMENT,AIR 4
10110015 6130009256400 POWER SUPPLY 6
10177187-1 6140010140595 BATTERY,STORAGE 23
10178430 5895009909047 ATTENUATOR,MODULE 35
10178434 4935009388127 FUNCTION LOGIC 7
10179949-1 6210004332533 LIGHT, INDICATOR 450
10182387 6140010594744 BATTERY,STORAGE 23
10243441 5990006892949 SYNCHRO ASSEMBLY 34
10282562-3 6625012125005 INDICATOR,DIGITAL DISPLAY 13
10407B 4931005866100 EXTENDER 4
10668616 4320010714163 PUMP 10
10668616-10 NONE BEARING 10
10672192 1430004082542 CASE 1
10674295 5985010530932 TRIPOD, ANTENNA ASSEMBLY 22
10892788 2590008600578 CYLINDER ASSEMBLY,ACTUATING,LINE 3
10892966 5210009913157 GAGE,THICKNESS 6
10930244 2805011245058 HOUSING ASSY,FLYWHEEL 1
10943726 2520008718442 COOLER,FLUID,TRANSMISSION 10
11069391 NONE CONNECTOR AS11071718-1 3
11071718-2 5935YETB25301 CONNECTOR 11071718-2A 1
11073591 4240010600533 RESTRAINT 2
11510500-3 5905012542741 VARISTOR 69
11510503 5955012259930 CRYSTAL UNIT, QUARTZ 3
11510540 6105013692533 MOTOR,ALTERNATING CURRENT 2
11566497-002 1430011473297 AMPLIFIER RADIO FREQUE 2
11566539 6130010650516 POWER SUPPLY 48
11568105 1430011268582 CASE,CARRYING-SENSO 6
11571209 6150012010982 CABLE ASSEMBLY,SPECIAL PURPOSE,E 5
12377302 2520013184507 TRANSMISSION TORQUE 8
12812-4 NONE BUMPER 1
13007044 1420010821732 LOGIC BD ASSY A5 10
13038581-2 5340014853672 SLIDE DRAWER EXTENSION 14
13038925 NONE COVER ACCESS 1
13142983-20/13 3030011504784 BELTS,V,MATCHED SET 3
13153176 5960011724526 ELECTRON TUBE 8
13153362 1430011714118 CAMERA YOKE ASSEMBL (CHAP) 6
13204250 3010011477147 CLUTCH ASSEMBLY FRI 5
13211E3793-5 4130001393372 COMPRESSOR UNIT,REFRIGERATION 2
13216E6309-2 4130011078008 COMPRESSOR UNIT 1
13218269 4310011602793 COMPRESSOR, ROTARY 3
13220916 NONE HOSE,ASSEMBLY 30
13228E1254/1 NONE DOOR 11
13229E4176 5905015556471 RESISTOR,THERMAL 1
13235011 5985013060417 RADOME 1
13238878 3010013325487 CLUTCH ASSEMBLY 2
13384778-001 6685013702252 TRANSMITTER, PRESSURE 3
13384785 4820013739011 SERVO VALVE HYDRAULIC 9
13458315-1 6105014347723 MOTOR,CONTROL 1
13458317-1 7050014341531 ENCODER-AZIMUTH 1
13458943 6625014480376 RECEIVER MODULE 1
13458948 6625014341205 OSCILLATOR SUBASSEMBLY 1
13458949 6625014341207 OSCILLATOR SUBASSEMBLY 1
13459004 5998014341210 CIRCUIT CARD ASSEMBLY 1
13526454 5895014204989 CONVERTOR, FREQUENCY, ELEC 7
13526480-002 5998014541021 CIRCUIT CARD ASSY 4
14000358 5810013235121 MWO KIT 3
1455B 4920010218513 VOLTAGE DIVIDER 1
1569701 1420009165120 WING,ASSEMBLY,GUIDED 20
1569711 1420009165121 WING,CAST ASSEMBLY 20
1796080 4720000048249 HOSE, AIR DUCT 6
2000SM-OR 2910014494341 ELEMENT ASSEMBLY 5
214-1731-01 5999010068392 HEAT SINK, ELECTRICA 5
260P27496S2 5910010950717 CAPACITOR,FIXED,METALLIZED,PAPER 2
301655 5998001487614 CIRCUIT CARD ASSY 1
4012413G2 TRANSMITTER ASS 4012413G2 2
4012415G3 DISTRIBUTION 4012415G3 1
4012577G1 HVPS,TMTR 4012577G1 1
4012654P1 FAN 4012654P1 3
4013074P1 TWT 4013074P1 1
4013394P2 EVALUATION,MOT 4013394P2 8
4015459P2 NONE MOTOR-DRIVER 4015459P2 (6110YETB07533) (CHAP) 3
4016661G5 ANTENNA ASSY 4016661G5 4
4038674G4 CONTROL BOX 4038674G4 2
40486644G1 DRIVER 40486644G1 1
4068733-0501 5998014609330 CIRCUIT CARD ASSEMBLY 1
50008572 2940121727164 FILTER ELEMENT, FLUID 30
50008576-1 4720123249814 HOSE, NONMETALIC 8
50008657 2910121954782 FILTER ELEMENT, FLUID 10
50008903 2910123259516 FILTER, ELEMENT FLUID (FUEL) 30
50008904 2930123249258 BLOWER, ENGINE COOLING SYSTEM 3
50008951 4730123245801 COUPLING HALF 7
50008970 5340123250263 BELLOWS .PROTECTION 3
50008992 5930121780068 GUARD, SWITCH 10
50009065 6680123249018 INDICATOR ELETRICAL 20
50009101 5930123249807 SWITCH, THERMOSTATIC 11
51002538 5340121797741 MOUNT RESILINT 5
5180-0219 NONE MERCURY RELAY ANALOG STIMULUS RESPONSE UNIT 3253A 5
5195184 143027HC00215 SBC/PMC-S10 ASSY 3
5420425 4320009476567 PARTS KIT,ROTARY PUMP 37
5420434 4440009990227 PARTS KIT,DEHYDRATOR 4
5704524 2910011574175 PARTS KIT, CARBURETOR 17
5704828 2910010284326 PARTS KIT,CARBURETOR 20
5800554 1290006140008 CIRCLE AIMING 3
5959151 6850000784459 HEAT TRANSFER FLUID 22
5962-8752701QX 5962012660259 MICROCIRCUIT DIGITAL 9
5K9052 5360012079013 SPRING 2
734F2MT-964-P5 NONE AGT RING ASSEMBLY LAUNCHER ACCUMULATOR 25
7374887 2920003537204 PLATE,IGNITION CONTACT BREAKER 3
81760-1 4130010485393 COMPRESSOR UNIT,REFRIGERATION 2
8363955 2510006793681 SPRING 48
8389622 4710004408382 TUBE, BENT, METALLIC 2
8636287 6645002556025 METER, TIME TOTALIZING 2
8733894 2530007743401 BRAKE SHOE 9
8740191 5315006794535 PIN,TOGGLE,EYE COLL 1
9065953 5985007549618 RADOME 8
9080201 9320010568016 RUBBER STRIP 30
9112775 6680007062990 REGULATOR,PRESSURE 2
9157601-13 5935000279937 CONNECTOR, PLUG, ELECTRICAL 20
9167642-72 1430010644462 MOTOR 1
9167664-15 1430000564710 CAP, FILTER 6
9167664-15 143000564710 CAP, FILTER 5
9167664-18 1430000564713 DIP STICK 21
9167664-19 6695000564714 GAGE, PRESSURE DIAL 7
9167664-36 1430000564768 TEE 9
9167664-68 1430010641416 SHAFT 40
9167664-70 1430010641418 COUPLING 25
9171473-32 1440001334070 SPOOL AND SLEEVE AS 5
9177314-17 1430009283672 BLOWER ASSY 10
9177314-23 5325009226501 GROMMET 10
9177314-38 6105009990858 MOTOR,COOLER UNIT 17
9177341 6645007396718 TIMERSTOP 5
9177346-43 1430009162063 HOUSING 20
9177346-46 4320009162062 ROTOR 34
9178833 1430004304226 ANTENNA 6
9183002 1450007120453 PAD, MISSILE REST 334
9190503 6130007903532 POWER SUPPLY 10
98-0204-0703-1 6850009640838 HEAT TRANSFER FLUID 6
A074847 5895002384596 CONVERTER, WAVE FORM 5
AN/USM-488 6625011877847 AN/USM-488 OSCILLOSCOPE 8
B3009CG29-0 6145000506723 CABLE 1
C4AZ7D026B 5330009103110 GASKET, INTERMEDIATE SERVO COVER 15
C5001092 5998014341198 CIRCUIT CARD ASSEMBLY 1
C5001099-1 NONE ANALOG CARD 2
CX10775/U375FT 5995001019828 CABLE ASSEMPLY,SPECIAL PURPOSE 1
D6AZ7CC391-B 2520010864004 PARTS KIT HYDRAULIC TRANSMISSION 3
DFNP6010-3 5310000089330 NUT,SELF-LOCKING,PLATE ALCOA FASTENING SYS DIV HUC 120
EQAZ7153B 2520010322175 PARTS KIT,TRANSMISSION 15
FC-77 6850009059098 HEAT TRANSFER FLUID 6
G286841-1 5962010043873 MICROCIRCUIT,LINEAR 2
K258642 5930012324914 SWITCH,SENSITIVE 100
K842530 4310012324909 PISTON CHECK ASSY 10
M22885/9-407 5930012561558 SWITCH M228519-407 5
M39006/09-8219 5910011194316 CAPACITOR,FIXED 2
M39019/01-6S NONE CIRCUIT BREAKER 10
M5757/30-045 5945000082615 RELAY 6
M83421/01-5005R 5910012275194 CAPACITOR, FIXED C1,C2 100
M83421/01-5029R 5910012834234 CAPACITOR, FIXED C1,C2 100
M83421/01-5101R 5910011579946 CAPACITOR, FIXED C1,C2 100
MIL-C-87252 9150013040885 LIQUID COOLANT, DIELECTRIC COOLANT-HEAT 20
MIL-T-43182 8340008236965 TENT MISSILE SYSTEM (AFT) 5
MIL-T-43512 8340009857431 TENT MISSLE SYSTEM (AFT) 5
MIL-T-43512 8340009857432 TENT MISSLE SYSTEM (AFT) 5
MS3108B12-5SC 5935008194929 CONNECTOR,PLUG,ELECTRICAL 2
MS39006/22-0454 NONE CAPACITOR 19
RB16CE140R5B 5905002367543 RESISTOR FIXED,WIRE 1
RB18488 4820009190849 VALVE,REGULATING,FLUID PRESSURE 9
RS4-605-24 4935011424630 WAFER,ROTARY SWITCH 10
SM-C-800908-1 6130010893565 POWER SUPPLY 1
SM-D-803152 5998010922752 CIRCUIT CARD ASSEMBLY 1
SM-D-803165 6110010886676 AMPLIFIER,ELECTRONIC CONTROL 1
SMB586379 5985008342125 SWITCH RADIO FREQ 4
SSRI-1812ZZRA5P25L668 3110007294872 BEARING,BALL,ANNULA 34
rksnow69
Return to Government and Defense
Users browsing this forum: No registered users and 3 guests
cron
