B747-200 Spareparts
Classified forum for your aircraft offers.
B747-200 Spareparts
Postby n_broda on Tue Feb 10, 2009 4:48 am
№ Part Number Description Qty Certificate Condition:
1 40885 Valve control unit 1 EASA SV
2 50234-1 Hydraulic pressure Tx 1 EASA SV
3 58173 Hydraulic motor 1 EASA SV
4 148085 Valve shut off motor 2 EASA SV
5 218387 APU fuel pump 1 EASA SV
6 260591 Compt and supply duct T indic 4 EASA SV
7 260593 Compressor discharge T 1 EASA SV
8 521313 CSD oil T indicator 1 EASA SV
9 701284 Flash head 1 EASA SV
10 701285 Power supply 2 EASA SV
11 2670112 Modular assy safety ldg door 1 EASA SV
12 622-3371-001 HF Rx/Tx 1 EASA SV
13 822-1045-401 VHF Com Tx 1 EASA SV
14 20414440404 Wx antenna drive unit 1 EASA SV
15 10106-03 Fuel qty indicator 7 EASA SV
16 10107-04 Fuel qty indicator 1 EASA SV
17 109300-16/18 Pneumatic drive 2 EASA SV
18 109395-2 Shut off and control valve 1 EASA SV
19 109501-501 Shut off and control valve 1 EASA SV
20 1176T100-3 Drive unit t/edge flap alternate 1 EASA SV
21 1387T100-11 Actuator rotary 1 EASA SV
22 1387T100-9 Actuator rotary 1 EASA SV
23 200-007-005 Hydraulic qty indicator 2 EASA SV
24 200-007-006 Hydraulic qty indicator 1 EASA SV
25 200-099-002 Hydraulic qty indicator 1 EASA SV
26 2041222-0401 Radar indicator 1 EASA SV
27 2156-2C Cargo Smoke detector 4 EASA SV
28 21B73-2-A Generator control unit 2 EASA SV
29 21B77-2-B Bus power control unit 1 EASA SV
30 2222601-6 Flight data acquisition unit 1 EASA SV
31 2-418-05 Transformer-rectifier 4 EASA SV
32 2588696-904 Lineas accelerometers 2 EASA SV
33 2590622-934 Pitch computer 1 EASA SV
34 2590623-912 Roll computer 1 EASA SV
35 2590625-902 Flight controller 1 EASA SV
36 2591027-905 Monitor and logic unit 1 EASA SV
37 2591201-921 Compass coupler 2 EASA SV
38 2591202-901 Compass controller 2 EASA SV
39 2670112-M1 Modular assy safety ldg door 1 EASA SV
40 2-792-02 Battery charger 1 EASA SV
41 29310-6 Outboard flgt spoiler ctrl package 1 EASA SV
42 30001300-021 Control package central lateral 2 EASA SV
43 3170120-5 Actuator assy 1 EASA SV
44 3170120-7 Inboard aileron actuator 1 EASA SV
45 3170130-4 Outboard aileron actuator 1 EASA SV
46 32-2684-007 Air shut off valve 2 EASA SV
47 3320500-1 Spoiler actuator 1 EASA SV
48 3320500-2 Spoiler actuator 1 EASA SV
49 3320550-1 Actuator Assy 3 EASA SV
50 3320550-4 Outboard flgt spoiler ctrl package 1 EASA SV
51 3320550-5 Actuator Assy 2 EASA SV
52 3320600-1 Actuator assy ground spoiler 1 EASA SV
53 350880-6 Hydraulic pump variable 2 EASA SV
54 350880-7 Hydraulic pump 1 EASA SV
55 36370-6 Modular assy pressure system 4 EASA SV
56 40-300-1 SAT indicator 1 EASA SV
57 40-302-4 TAT indicator 1 EASA SV
58 40-309-1 TAS indicator 1 EASA SV
59 4066010-910 TCAS computer 1 EASA SV
60 40-885-2 Valve control unit 2 EASA SV
61 42-189-7 CBH-SCBS (skide brake) 1 EASA SV
62 42-319-3 Auto brake unit 1 EASA SV
63 50234-1 Transmittor pressure 3 EASA SV
64 50483-19 Indicator hydrau 1 EASA SV
65 50483-20 Hydraulic pressure indicator 4 EASA SV
66 522-2996-011 Marker beacon Rx 3 EASA SV
67 5426-234-8 CSD oil T indicator 3 EASA SV
68 57186-07 Pump hydraulic 1 EASA SV
69 605457-7 Fan centrifugal 1 EASA SV
70 60-72301 Motor impeller sub assembly 2 EASA SV
71 60-72301-3 Motor impeller sub assembly 2 EASA SV
72 60946-5 Accumulator cylindrical type 1 EASA SV
73 60B00107-1 Dual duct pressure indicator 1 EASA SV
74 60B00258-4 Flight ctrl shut off module 2 EASA SV
75 60B40019-2 Battery charger 1 EASA SV
76 60B40042-3 Tx control surface position 3 EASA SV
77 60B40141-4 Fuel flow rate indicator 2 EASA SV
78 60B92406-32 Actuator elec motor operated 1 EASA SV
79 60B92406-34 Actuator elec motor operated 1 EASA SV
80 617154-5 Control unit window heat 2 EASA SV
81 622-2921-001 DME receiver 1 EASA SV
82 64141-862-1 Altimeter 1 EASA SV
83 65B43701-4 A/T DAB 1 EASA SV
84 65B47501-12 Leading edge flaps display logic 1 EASA SV
85 65B47505-52 Leading gear prim system logic 1 EASA SV
86 65B81121-10 Gearbox assy R/H 1 EASA SV
87 65B81126-221 Transmission 1 EASA SV
88 65B81126-222 Transmission 1 EASA SV
89 65B81127-70 Transmission 1 EASA SV
90 65B81128-15 Transmission 2 EASA SV
91 65B81129-170 Transmission 1 EASA SV
92 65B82507-23 Hydraulic reservoir 1 EASA SV
93 67-2985-002 Valve air shut off line 1 EASA SV
94 68160-2 Trailing edge flap control 1 EASA SV
95 69B46114-6 Landing gear panel 1 EASA SV
96 704185B Load controller 1 EASA SV
97 704185C Load controller 1 EASA SV
98 704185D Load controller 2 EASA SV
99 705-7V9M1 Horizon gyro 1 EASA SV
100 710298-8 Selector panel 1 EASA SV
101 717998-4 Compressor bypass check valve 1 EASA SV
102 719223-4 Valve turbine bypass 3 EASA SV
103 719224-4 Trime air valve 1 EASA SV
104 719238-9 Air cycle machine 1 EASA SV
105 720472-5 Zone temperature control 1 EASA SV
106 720472-7 Control zone temperature 4 EASA SV
107 738362-22 Pylon valve 1 EASA SV
108 738362-23 Pylon valve 1 EASA SV
109 747-5700-3-0 PDU 1 EASA SV
110 750399-3 Water separator 3 EASA SV
111 767460-2 Valve flow control 2 EASA SV
112 777-1328-001 Coupler antenne 1 EASA SV
113 777-1329-001 Control antenne coupler 2 EASA SV
114 777-1397-001 Indicator horizon 2 EASA SV
115 777-1492-004 ADF receiver 3 EASA SV
116 777396-1 Cabin pressure control 1 EASA SV
117 7886580-011 Carousel Navigation Unit 2 EASA SV
118 7886800-151 PMS computer unit 1 EASA SV
119 7891780-041 Limit indicator 1 EASA SV
120 8DJ164LWX2 Fuel flow rate indicator 1 EASA SV
121 8DJ164LWX3 Fuel flow rate indicator 1 EASA SV
122 9-103 Fuel used indicator 4 EASA SV
123 9-113-19 Electronics fuel flow 1 EASA SV
124 9550626-1 Brake T monitoring system 1 EASA SV
125 964-0076-004 Comparator rudder ratio changer 1 EASA SV
126 9800-2D1A-BF23A Portable oxygene cylinder assy 2 EASA SV
127 9819-2902 CSP indicator 1 EASA SV
128 A4289910016 Altimeter 2 EASA SV
129 D428-01-001 Engine fire shut-off switch 4 EASA SV
130 HG 480 C1 Digital air data computer 1 EASA SV
131 MA11A1194 Fuel feed actuator 1 EASA SV
132 NA 135 Selcal decoder 1 EASA SV
133 ST106AB Transmitter pressure 1 EASA SV
Contact:
Mr. Nikita Broda
Marketing Manager
Volga-Dnepr Gulf
broda@vdgulf.com
+971 50 342 9097
n_broda
Return to Fixed wing
cron
