Aircraft Painter
Aircraft Painter
Postby Guest on Thu Jan 20, 2011 11:24 am
Aerotek Aviation, LLC - Warner Robins, GA, US
Summary
Aircraft Painter
The Aircraft Painter coats surfaces of aircraft with paint, lacquer, epoxy, resin or other material, using brushes, rollers, spray guns and other devices, removes old paint from aircraft, using liquid paint remover and scraper. Smoothes surface with sandpaper and steel wool, roughens aluminum surfaces with acid solution and steel wool to insure that paint adheres to surface, masks and covers portions of surfaces not to be painted, and paint insignia, letters or numerals on aircraft surface, using stencils.
Minimum Requirements:
Must have 36 months experience painting, robotic media blasting and preparing Aircraft surfaces for painting. Formal Training and computer (CNC) operated painting experience preferred. Military Aircraft experience preferred, DEPOT level work performed on F-15, C-5 and C-130. Applicants are advised that this list of duties is not meant to be all inclusive, applicants will be required to perform all other assigned duties. A current drivers license and insurance is required for access to the military installation. Must pass Base back ground security check.
Qualifications
Painter
Company profile:
Aerotek Aviation, LLCSM delivers expertise and talent to the aviation industry. We provide experienced mechanics, technicians, engineers and skilled specialists for both fixed and rotary wing aircraft to the Commercial and Cargo Airlines, Military, General Aviation and FAA Regulated Services and Manufacturing sectors. Whether you're seeking employee management services or a career opportunity, you'll find that Aerotek Aviation has the expertise to create that perfect fit.
Aerotek Aviation is the perfect partner. We have built our success through developing lasting, positive relationships with our clients, candidates and employees, and maintaining a level of quality, service and professionalism unrivaled in the industry. In addition, Aerotek Aviation has the distinct advantage of having over twenty primary locations throughout the United States to serve you.
Direct employment inquiries to:
440 Roper Mountain Road
Greenville, SC, 29615
US
Company Telephone: 864-236-3389
Company Fax: 864-236-3396
Company web site: http://www.aerotek.com
Guest
MEMBER
Return to Military Aviation Jobs
