BOMBARDIER CRJ & DASH 8 INVENTORY - FOR SALE
Postby walsales on Tue Feb 18, 2014 12:42 pm
CONTACT: Email: marketing@wal-llc.net P(954)746-6411
E140319-2 FLEX SHAFT NE
SEL-OC19DW INT TEMP INDICATOR OH
SEL-OC29DK RPM INDICATOR OH
066-50001-1001 VSI INDICATOR (IVA-81A) OH
1104SD100-201 Shaft, Flex Drive NE
1104SD100-301 Shaft, Flex Drive NE
1104SD100-401 Shaft, Flex Drive, Outbd NE
1104SD100-501 Shaft, Flex Drive, Outbd NE
12D1006 VALVE CHECK OH
1603730-005 CONTROL THROTTLE OH
1697M50G01 CABLE ASSEMBLY W2 BLUE OH
1697M50G01 ELECTRIC CABLE OH
228-50162-417 DOOR ASSY LH LWR COWL OH
228-50162-418 PANEL , CORE COWL RE
228-50181-245 FAIRING EXHAUST NOZZLE RE
228-50208-238 ASSY LOWER TRANSLATING RE
228-50230-803 BLOCKER DOOR ASSY NE
228-50232-801 BLOCKER DOOR RE
228-50231-801 BLOCKER DOOR RE
228-50232-801 DOOR UPPER BLOCKER RE
30-326E-7 CONTROL AMPLIFIER OH
4060T64P01 OIL FILTER BYPASS RE
4060T64P01 OIL FILTER BYPASS TESTED
4122-006000 PUMP . UAX PROP FEAETHERING OH
472698 FIRE DET CARD OH
4926-201 RADOME RE
5122T11G01 OIL TANK OH
601-50910-17 WIRING HARNESS RE
601-80003-3 DUCT ASSY RE
601R43127-1 DRAIN VALVE OH
601R41255-6 PANEL COCKPIT RE
601R57900-5PE ENGINE HARNESS RE
601R57900-13 #2 FIRE DET HARNESS NE
601R57900-13 HARNESS # 2 OH
622-8971-020 TRANSMITTER RECEIVER OH
622-8973-001 TCAS ANTENNA OH
63228-2 BOX ASSY CONTRL RE
692545-18 SOLENOID SHUTOFF VALVE OH
7002260-722 SERVO DRIVE OH
7010133 FLUX VALVE OH
7SC0299 VALVE SOLENOID NE
754691-1 SENSOR IP
768965-2 FUEL PROBE IP
782100-4 PRESSURE SWITCH TESTED
82760174-006 RH ELEV TRIM SCREW JACK OH
82760174-006 JACK SCREW ASSY RH NEW
82970065-003 DAMPER ASSY RE
87110047-001 STRUT VERTICAL ASSY RE
900-700-035-35 BOTTLE OXYGEN OH[/size]
walsales
Return to For Sale
