Need URGENT Military Parts
Military parts and aviation
Postby rendeep on Thu Feb 06, 2014 2:29 am
Hello
Urgently need Below mentioned Military Parts.
Pls provide RFQ
S No PN NOUN U QNTY
1 109963-01 DISK PLATTER EA 9
2 111307907 SUPPORT EA 4
3 801245-2 BRACKET ASSY MISSILE EA 4
4 801245-1 BRACKET ASSY MISSILE EA 4
5 556-001 VALVE REGULSTOR EA 10
6 SM-B-447480-1 SPACER, SPECIAL EA 5
7 12277548 BOOT,DUST AND MOIST EA 13
8 724306-1 AIR CONDTIONER EA 4
9 SMC44877213 CAPACITOR EA 10
10 SMC6207581 CAPACITOR EA 10
11 663251-301 SWITCH PROTECTOR EA 10
12 SMD449049 COIL,RADIO FREQUANCY EA 10
13 SMB447726 SEMICONDJCTOR DEVICE DIODE EA 10
14 108131-01 SERVO PCBA EA 10
15 CX-4722-VRC CABLE ASSY EA 26
16 3061 PRINTER PAPER EA 10
17 K208-1012 SEAT AXLE SPRING (LH)-FRONT FRAME- EA 30
18 K103-200-6 CROSSMEMBER LH EA 2
19 836-0222 BREATHER 1/8 IN-NPT EA 3
20 352-0462 FLANGLE REAR OUTPUT EA 17
21 2810E369 CAMSHAFT RH - CAM BREAK SPIDER MOUN EA 3
22 3819U359(LAST PROC) DRUM BRAKE RR AXLE EA 14
23 278024 SLACK ADJUSTER 6-1/2' EA 71
24 A20-3200R1032 DIFFERENTIAL ASSY EA 2
25 67MR1 KIT WINDOW REGULATOR MAN LH DR EA 24
26 RD3-2227-0 PANEL ASSEMNLY CONTROL L HTR & A/C EA 15
27 K385-2121-070 CABLE BATTERY , 6 V EA 14
28 D6427-3092 CABLE BATTERY , 6 V EA 135
29 S354042 TOWING HITCH TRUCK EA 15
30 NTA400 ENGINE ASSY DISEL ,40 - HP,5-1/3"X'X6 EA 30
31 AR09911 BLOCK CYLINDER EA 14
32 3801781 KIT CYLINDER EA 149
33 3014404 NOZZLE PISTON EA 14
34 3019491-2951 PUMP ASSY FUEL PT (G) -UNCALBRATED EA 2
35 1990456 STARTER ENGINE ELETRICAL 24V EA 77
36 1115558 SOLENOD,SWITCH STARTER # 11147100 EA 14
37 142608 CORE ASSY OIL COOLER EA 23
38 AR9066 PUMP WATER USE NNHA 2930SAL072795 EA 3
39 B20AH FILTER OIL TRANSMISSION(I&S LF -509N EA 132
40 BBB11-7808 FILTER A/C LEANER SUPS BY SMP 18-10-36 EA 33
41 B182036 FILTER ELEMENT AIR EA 18
42 28623 BELT V A/C DRIVE EA 6
43 RR-27-B SHAFT ACTUATING WORM BREAK EA 3
44 233282 REPL BY PIN JHM516810- CUP TAPERED EA 2
45 RR626 OVERDRIVE CHAIN ASSY EA 14
46 41562 CLUTCH FREON EA 5
47 AR04154 PARTS KIT COMPRESSOR EA 14
48 3018527 AIR COMPRESSOR (SSD BY -3018534) EA 3
49 K18-3525 PIPERADIATOR (UPPER)RADIATOR PIPING EA 6
50 202994 HOSE AIR CROSSOVER EA 23
51 K342-258-140 HOSE AIR EA 26
52 K342-256-124 HOSE ASSY 124LG RLB 472-SAL 071017 EA 8
53 K342-458-32 HOSE GEAR BOX EA 189
54 D9043-3143 HOSE ASSY HEATING & AIR CONDITIONER EA 3
55 130394 COMUPLING WATER MAN GEA/PG EA 17
56 S-1090 ELBOW AIR COMPRESSOR EA 23
57 MA1030 VALVE AIR USE EA 149
58 K240-793-2 WRENCH TUBE ASSY ( ONLY)SZ 85 MM EA 5
59 927667 SUPS BY P/N 927775-002(WASHER.I/D EA 74
60 13444 CLAMP NUT CABLE EA 3
61 927427 WASHER COOPER APPLY AIX TMISSION TC8 EA 15
62 BE-46 PIN ;LUNGER HOUSING TRUCK MASTER EA 18
63 A1205T1450 SEAL OIL HOUSING FWD RR AXLE SHAFT EA 5
64 427374 GASKET INTERMEDIATE SHAFT APPL TC80 EA 23
65 427-0 372 GASKET INPUT SEAL CARRIER CASE CAPS EA 21
66 782288 O-RING PISTON SHAFT SEAL APPL TC800 EA 18
67 201701 GASKET THERMOSTAT HOUSE EA 20
68 A1805A575 SEAL OIL EA 45
69 370119A OIL SEAL HUB BEARING EA 9
70 226961 SEAL OIL BEARING CAP EA 2
71 C68-3299V BRACKET ASSAMBLY LH FWD RH READ EA 6
72 31S SPRING MOUNT ENGINE RADIATOR EA 3
73 RR-55 SPRING WORM BREAK EA 3
74 744279 SHIM (0,015)PINK APPLL TRANSFERE GAS EA 48
75 744289 SHIM (0,015)PINK APPLL TRANSFERE GAS EA 8
76 736-0896 RING BEARING SACER EA 63
77 736-897 SWITCH SERIES S/PARALLEY EA 57
78 KT 301-59 SWITCH SERIES S/PARALLEY EA 3
79 4024808 SOLLENOID ELECTRICAL EA 2
80 D63,3-1232(ST PROC) CABLE BATTERY EA 12
81 K385-2144-085 CABLE BATTERY EA 2
82 K385-4131-051 GAUGE OIL TERMP (REPLY BY P/N 465CS) EA 75
83 K152-199-1 GAUGE TACHOMETER EA 69
84 VST23060S GAUGE TACHOMETER (SUPS BY K152-261-1 EA 4
85 K152-181-8 THERMOSTAT FLOW CONTROL EA 3
86 201727 THERMOSTAT FLOW CONTROL EA 50
87 11826061 PLUGER, EXTRACTOR EA 12
88 11826067 EJECTOR CARTRIDGE EA 6
89 11826165 COVER ASSY EA 15
90 11826230 TRIGGER & FRAME ASSY EA 45
91 7575466-001 GYRO ASSY EA 15
92 5564174 BRUSH,CLN,SM ARMS BORE/2 EA 474
93 84484666 BRUSH,CLEANING SMALL ARMS EA 266
94 F053110046900 MUZZLE GUN,EQUIPED EA 5
95 F5316BJ08829M GUNNER CONTROL PANEL UNIT EQUI EA 5
96 F05310085524 ANALYSIS BOX,PACKED EA 27
97 F28336932-10002 CAPITOLE SIGHT EA 32
98 7574651-011 CONTROL DISPLY ASSY EA 5
99 167505-11-02 VEHICLE REFERENCE UNIT (VRU)MODEL EA 2
100 2201-6095,04 PERISCOPE,M17 EA 36
101 F62351060559 RANGEFINDER TCY901 EA 12
102 7575423-001 HIRE COMMANDER DISPLAY EA 9
103 7575427-001 TELESCOPE UNIT HIRE EA 5
104 706733 PERISCOPE,NIGHT DRIVING,NAP5-3 EA 2
105 5095350 CASCEM CALCULATOR EA 9
106 A2-007575425-001 ELECTRONIC,UNIT EA 9
107 C04151361034-31000-00 GUIDANCE ELETRONICS EA 17
108 C04151361086-44000-00 JUNCTION BOX WITH BUILT UNIT TES EA 15
109 F053110047725 DOOR ,COMMANCER,S EQUIPPED EA 6
110 BW10553865 HYDRULAIC BRAKE ACTUATOR ASSY,FRT EA 2
111 F053110085525 BOX,CONTROL,PACKED EA 5
112 F5316BJM03060M AZIMUTHAL AIMING BOX EA 8
113 F5321033093X BOX CE 02 EA 12
114 2424-4302,01 WATER CONTAINERS EA 15
115 7574572-011 MANUEL DRIVE ASSY EA 2
116 10503837 BLADE WINDSHELD WIPER EA 2
117 10551184 COVER WEATHER PROTECT EA 83
118 BT10505016 SUPORT ASSEMBLY ,WEATHER PROTCTION EA 2
119 BT10554160 ADAPTER,MOTOR EA 5
120 706493 FRAME,SUPPORT EA 2
121 708929 HOUSING EA 2
122 10554255 LOUVRE,BALL EA 2
123 10554987 BLANKET,LEFT EXHUST EA 51
124 10554988 BLANKET,LEFT EXHUST EA 2
125 2402-4523,14 HORN EA 9
126 2424-3910,10 OUTRIGGER EA 3
127 F5316BJM03073M HANDWHEEL VETICAL AIMING EA 3
128 F5316BJM08069M DESK AIMMING CONTROL EQUIP EA 6
129 10502006 SWITCH BEAM SELECTIVE EA 11
130 4410553776 WIRING HANESS W 5 EA 2
131 10553927 PUMP FUEL ASSY EA 23
132 10558893 FILTTER ELEMENT FLUID EA 21
133 10554555 FUEL PUMP EA 60
134 10512098 ELEMENT R/B PN;10552593 EA 131
135 10553928 PUMP FUEL ASSY EA 30
136 23506011 PUMP ENGINE COOLANT EA 5
137 313093-091 RADIATOR CAP ASSEMBLY EA 12
138 10502009 ELEMENT R/B PN;10552593 EA 12
139 7099 GEAR POWER TAKE OFF EA 2
140 10553841 BEARING ASSEMBLY STEERING EA 3
141 217717 NEEDLE THRUST BEARING EA 2
142 217716 ROLLER BEARING BACKPLATE EA 2
143 920137 SOLDERING IRON 220V,50W EA 2
144 920139 SPARE TIPS FOR SOLDERING IRON EA 6
145 900695 HOOK ATTATCHMENT EA 3
146 10501725 ETINGUSHER,FIRE,M EA 177
147 1131935 COMPERSSOR EA 3
148 F05310223373 PUMP,5L IN BOX EA 3
149 BS10511888 TUBE ASSEMBLY EA 2
150 10553188 TUBE ASSEMBLY EA 5
151 10518324 HOSE ASSY EA 14
152 10501362 HOSE NONMETALLIC EA 2
153 10552523 HOSE ASSY EA 2
154 709213 HP HOSE L=1320 EA 3
155 10503822 HOUSE ASSEMPLY EA 3
156 2605-1372,01 HOSE HIGH PRESSURE EA 3
157 2607-0999,03 HOUSE ASSEMPLY EA 5
158 10502635 COUPLING EA 3
159 10500594 CONTROL VALVE P.B EA 2
160 2401-0539,05 VALVE EA 812
161 F5307229012B EXTENSION ROAD ALVE EA 2
162 703655 TIRE IFLATOR ADAPTER EA 15
163 11826060 EXTRATOR CARTIDGE EA 3
164 2420-9897,05 VEHICLE HYDROULIC JACK 3
165 708795 TYRE INFLATION/VEHICLE START TROLLE EA 2
166 708801 STATOC TYRE EXCHANGE UNIT FOR REMOV EA 2
167 0 925310 CLINDER HOME EA 2
168 F62351060573 BRORESLIGHT.LASER RANGE FINDER EA 6
169 307-032-0007 HEAD SPACE GAUGE EA 3
170 11826299 HEADSPACE WARNING GAUGE EA 2
171 900693 ASSEMBLY RING NM2 EA 6
172 0 900137 HOOK TOOL EA 2
173 0 900147 ADAPTOR EA 2
174 0 900228 SEAL INSTALLER EA 2
175 0 900251 SEAL INSTALLER EA 2
176 0 900162 SPECIAL WRENCH EA 2
177 0 900232 SLOTTED WRENCH EA 2
178 BT-HT-100 T-HANDLE WRENCH,1/2'R/BY PN TM5 EA 2
179 BT- HT-107 T-HANDLE WRENCH 3/8' EA 2
180 CM264-10 ADAPTOR TOOL EA 2
181 CM264-12 ADAPTOR TOOL EA 2
182 CM264-14 ADAPTOR TOOL EA 2
183 CM264-18 ADAPTOR TOOL EA 2
184 CM264-20 ADAPTOR TOOL EA 2
185 CM264-22 ADAPTOR TOOL EA 2
186 CM264-8 ADAPTOR TOOL EA 2
187 A62413A DIPSTOCK SET OF 3 PCS EA 3
188 0 901055 ANGLED GRINDER EA 2
189 0 203606 TOOL KIT METRIC EA 35
190 400628 SCREW CAP HEX HD EA 2
191 MS90728-113 BOLT EA 75
192 409865 WASHER,LOCK WASHER FLAT EA 5
193 MS35338-44 SPRING PIN.SLOTTED,EAVH TYRE EA 752
194 MS51968-2 NUT,PLAIN,HEX EA 3
195 120382 WASHER LOCK EA 144
196 10500654 WASHER,FLAT EA 3
197 3000009190 SPRING PIN SOLTTED HEAVY TYRE EA 3
198 F5307221023S KEY MACHINE EA 5
199 10555052 DRIVE KEY EA 2
200 0 700049 PACKING PREFORMED 2,62 X DIAM./52. EA 86
201 5120540 GASKET EA 2
202 10556193 FUEL PUMP GASKET EA 8
203 709636 W-RING EA 8
204 10500111 SEA;,RUBBER,SPECIAL EA 5
205 2418-1021,02 SEAL EA 14
206 0 902343 RESTRAINING STRAP COMPLETE EA 15
207 0 705427 THREAD INSERT PLUG M10X90 EA 38
208 7266115 HANDLE ASSY CLEANING ROD EA 2
209 10503746 ROD CONTROL EA 5
210 3602002721 CLIP RETAINING FEED CHANNEL EA 3
211 BS10514575 BRACKET EA 2
212 BW10554372 LATCH ASSEMBLY SPRING EA 2
213 0 203272 STRAP ASSY,2500M EA 6
214 0 203980 STRAP ASSEMNLY EA 63
215 0 706230 BOOT SEALING EA 102
216 0 706231 CLAMP EA 8
217 0 924304 BRACKET OIL CAN EA 2
218 10512546 PLATE BASE EA 2
219 10512739 CATCH FRICTION EA 2
220 10514288 DIAPHRAGM EA 2
221 MS91528-1E2B KNOB CONTROL EA 72
222 MS91528-0C1B KNOB EA 33
223 3602008308 SPRING COMPRESSION EA 2
224 10514077 SPACER GOVERNOR EA 2
225 3662001278 BEARING BREECH THREAD EA 6
226 217545 SHIM-TH,0,1MM EA 3
227 217546 SHIM,TH,0,2MM EA 3
228 BCC610SA CREWMANS PERSONAL UNIT EA 15
229 F053110085523 MICROMONITOR PACKED EA 17
230 442762 IMAGE INENSIFIER TUPE EA 14
231 477870 POWER BOARD EA 2
232 0 201763 NIGHT VISION SET BIG,2 EA 2
233 BCC605SA CREWMANS FIXED BOX EA 6
234 28132-340-01 RES NETWORK 2,7 K 5 % S/R EA 23
235 10512390 SWITCH EA 6
236 2424-3904,02 ADAPTER EA 2
237 2420-4511,33 RELAY EA 6
238 10551129 SOLENOID CONTROL ASSY EA 9
239 RA310/1062 HEADSET EA 15
240 0 708081 STRAP TIEDOWN EA 206
241 0 709198 REMOTE CONTROL CONNECTOR BOX EA 2
242 10554770 MOTOR A/C DRIVE EA 3
243 F5321103682F ELECTICAL CABLE EA 2
244 2418-4555,00 OUTLET WITH CABLE ASSEMBLY EA 29
245 12524032 CONNECTOR TEST ASSY EA 18
246 D10-150M CABLE EA 2
247 49230-350-10 CABLE CORD EA 15
248 10553969-2 CABLE ASSEMBLY 89-89A EA 8
249 7575429-001 CABLE ASSY EA 2
250 0 700625 LAMP READING EA 3
251 2420-4511,91 LAMP SOCKET EA 6
252 101494-02 LIGHT SOURCE CONTROL EA 8
253 0 707085 LAMP 8 W EA 14
254 705559 LAMP ELECTRICAL 11 - V /55W EA 6
255 10554004 SENSOR FUEL LEVEL EA 15
256 10554544 FUEL LEVEL SENDER EA 12
257 7575408-011 MINITESTER EA 2
258 7575426-001 SENSOR UNIT HIRE (SR 2,338,456,91) EA 60
259 10505901 TIMER EA 2
260 413711 STADMIETER EA 2
261 2401-4511,08 TRCHOMETER EA 18
262 10554545 SENDER FUEL LEVEL EA 9
263 MS24537-1 TRANSMITTER TEMP EA 12
264 2401-4511,12 WATER TEMPERATURE GAGE EA 12
265 A-A-711 SOLVEN DRY CLEANINGN(20 LI/CN) EA 12
266 0 708745 ENGINE CLEANING SOLVENT ,200LI EA 45
267 0 709569 ENGINE CLEANING SOLVENT,25LI EA 29
268 F3005XS-58B,5L SOLVEN CLEANER 5 LI/CN EA 6
269 BR86910 DUSTPAN EA 14
270 10511428 TAPE, FASTENING EA 6
271 709467 THINER FOR RUBBER SEALANT EA 2
272 0 734145 ADHESIVE 3M, 1 LI EA 3
273 128123 FPOLYETHLEN BAG EA 5
274 0 708701 OXYGEN BOTTLES EMPTY EA 2
275 0 708765 BRAKE BLEEDING BOTTLE EA 2
276 0 706591 WORK GLOVES RE-INFORCED EA 2
277 0 709571 HAND CLEANER EA 168
278 0 890424 HUB EA 3
279 1617129 clutch booster EA 3
280 2608509 lock zyunder EA 8
281 2506786 tire,pneu 16,00x20 EA 210
282 3291004 orifice,control block complete EA 9
283 4790748 relay EA 2
284 1717005 prehaet start switch EA 15
285 0 746339 filter insert EA 24
286 0 890427 throw out bearing EA 5
287 2320002 house line EA 3
288 3000196 hose,metalic EA 8
289 54108301 tool set,electrician EA 6
290 1721085 rocher swich EA 2
291 1728028 battery, storage 12v-17. AH EA 173
292 1710254 PRIORITY VEH LIGHT EA 6
293 1794-680 HEADLIGHT,INSERT EA 4
294 102212 TRANSPORTATION BOX 1 W TEST SETS EA 3
295 0 501202616 TORSION PLATE EA 3
296 4253320000 CHAMBER , AIR BRAKE EA 3
297 2300002-131310 WHEEL ASSY PNEUMATIC TIRE, LEFT EA 3
298 4031500750 GENERATOR , ENGINE ACC EA 3
299 29.069,10,009 HEAT , EXCHANGER EA 3
300 4020701024 BRACKET , ENGINE CONTRO; EA 3
301 4020961690 HOUSE, PREFORMED EA 3
302 4029975382 HOUSE, NONMETALIC EA 5
303 C46120K18002-680-3 HOUSE, NONMETALIC EA 3
304 3.93,2-1704.1 BRACKET ,FLUID CONTAINER EA 3
305 0 601356073 RIGHT ANGLE GRINDER ABT EA 3
306 4021420080 GASKET EA 3
307 0 80000002012 GASKET EA 15
308 4421310380 GASKET EA 6
309 235ZM/50MM PADLOCK EA 5
310 601-2185 BOTTLE CONNECTION PIECE EA 3
311 VG96924T09-12V/100 AH BATTERY STORAGE 12V-100 AH EA 3
312 1013-16 HANDGUARD,PLASTIC ON EA 29
313 25-400 BUTTSTOCK ASSY, RETRACTABLE 2 - NOTCH EA 57
314 2283 BAYONET ,COMPLETE W SCABBARD (G3) EA 1314
315 25-410 BUTT STOCK,RETURACTABLE 2 - SOLT TYPE EA 80
316 25-416-01 BUFFER EA 48
317 1013-40350 STOCK,BUTT RETRATABLE WITH CAP EA 72
318 A4/3DIN6798 WASHER SERRATED EA 258
319 3602012226 CYLINDER , GAS EA 2
320 12/00/02/0041 BODY ,COCK SLIDER (R/B 12,00,02,0041A) EA 344
321 5019R-1100/05 DISK EA 2
322 29/00/05/0201 BOX MAGAZINE EA 159
323 47-R/ERGONOMICH/G HANDROUP ,ERGONOMIC,RIGHT EA 2
324 43-MK3AMBIDEXTROUS SAFETY ASSEMNLY, A,NIDEXTROUS EA 6
325 M3 DIN 546 NUT, SIGHT EA 6
326 210 RECIVER ASSY EA 4
327 HOLSTER-9MM PISTOL HOLSTER,PISTOL WEBBING MTL SAND COL EA 20
328 1013-101,49V3 MACHINE(DEVICE)HYDRAULIC-SOLDER EA 4
329 10040100W5 PLERS FLAT NOSED EA 4
330 SIZE 32 HAMMER PLASTIC EA 15
331 1013-01,89L11 GAUGE BARREL APPL HECKLER & KOCH AU EA 5
332 3614150030 SPRING,FOROMG [OM EA 20
333 A 03-2800 CAP ASSY, BATTERY HOUSING (SC00397) 20
334 1000025-30000 CYL ASSY, BLANCING GEAR EA 3
335 1000025-320000 CYL ASSY BALANCING GEAR EA 2
336 1000025-245000 VALVE CHECK EA 48
337 1000025-120000-34 HYDRAULIC DAMPER EA 5
338 1000025-1470000-01 PLUGER EA 2
339 1000025-143000 HOSING EJCTION EA 3
340 1000025-142000 LOADER VEN TUBE EA 9
341 1000025-142400-01 PIN FIRING EA 5
342 1000025-243000-0 PISTON EA 3
343 1000025-246000 INDICATOR EA 3
344 2-4610-0013-1 HOUSE VALVE EA 47
345 1/4/38002 GEAR SHAFT & SEARING ASSY EA 5
346 ST/W/0076 ADAPTER OIL CHARGING EA 3
347 FL18868 COVER GUN L 27 A EA 5
348 FH70/8/1/1005 LOCATING PIN XL 1 E 1 EA 2
349 7223 REGULATOR HIGH PRESSURE VENT TY EA 2
350 ST/W/0082 ADAPTER HIGH PRESSURE HOSE EA 2
351 1/3/210 39 STOP EA 3
352 ST/W/0093 RECUPERATION OIL CYL BLEED TOOL EA 2
353 1000025-260610 TTRAU LOADING EA 2
354 SS-19/MK1 QUADRANT FIRE CONTROLL 1 A 1 EA 5
355 FB680275 MASTER CYLENDER ASSY EA 2
356 60224 CATCH RUBBER EA 6
357 AOAS30X40X7X10-92AO504 WIPER EA 2
358 12691-77 WIPER EA 9
359 20DIN7757 VALVE CORE EA 45
360 0 21127025A PUMP FUEL CAM ACTUATED EA 17
361 29032008 LEAD ELECTRICAL IGN EA 6
362 C6653102 RPTPR AR, DOSTRIBUTOR EA 5
363 SR40X20MMBTFE561 BEARRING SLEEVE EA 11
364 1000025-280000-05 COVER EA 10
365 0 26-00-37B EAR PLUG (150 EA/BX) EA 10
366 A52491610-259 HOSE ASSY EA 4
367 GA9020371E00390GA1014E00700-090 HOSE ASSY EA 8
368 GA9020371E00390GA1014 HOSE ASSY EA 5
369 E00700-090 BEND PIPE RETURN EA 5
370 SCHRADER2755 VALVE CONNECTING EA 3
371 MZT FLOW DISTRIBUTOR EA 7
372 1.00003E+12 LIFTING ASSY BRRECH LOCK EA 3
373 14X15-MMA/F150-MM-O/ALG SPAR OPEN RING FLARE NUT TYPE EA 3
374 1,000,025,810000-1 C-SPANNER BRREL LOCKING RING EA 3
375 1.00003E+12 SPANNER WRENCH EA 3
376 36,0-MMAFX41,0-MMAF420 SPANNER OPN JAW FIXED DISL END EA 3
377 NOBARTNUMBER WRENCH RATCHET EA 5
378 1000025-230000-15 RING BACKING EA 10
379 1000025-243000-03 RING BACKING EA 10
380 1/4237031/4/23703 GASKET EA 7
381 1766316 RING SEALING TOROIDAL EA 3
382 1000025-240000-11 RING SEALING TOROIDAL EA 16
383 50OR99-2X5-7-85NBR829 SEAL EA 6
384 OR144-TX5-7-85NBR829 RING SEALING TOROIDAL EA 17
385 NI4400-30X45X10-80NBR878 SPACER RING EA 6
386 OR114-2X5-7-85NBR829 SPACER RING EA 10
387 SRA155X5-1X2-5 RING SEALING TOROIDAL EA 18
388 SR/36-5-1-1-5 RING SEALING TOROIDAL EA 10
389 OR3-52X5-7-85NBR829OR10 RING SEALING TOROIDAL EA 7
390 OR104-2X5-7-85NBR829 SPACER RING EA 5
391 OR82-2X5-7-85NBR829 VENT PLUG EA 3
392 SRA55-5-1-1-5 VALVE COVER BALANCING GEAR EA 8
393 1000025-310000-05 RING RETANNG/RB D 14000-0200APP EA 3
394 1000025- 245000-011/5/17710 SPACER RING EA 15
395 1000025-280000-06 RING RETANNG/RB D 14000-0200APP EA 8
396 S22713-F2-A107 SPACER RING EA 5
397 27500-45022NIV- KEYBOARD TELEPRINGTER T 1000V EA 5
398 27500-45022 SWITCH PUSH EA 5
399 NIV - 4 12 AMP MK PLUG EA 40
400 BZY88C5V1M4954 SEMICONDUCTOR DEVICE DIODE EA 10
401 M4954 RECTOFOER [M 6 A 4 Q EA 3
402 55103 BATTERY NONRECHARGABLE VENT SHOP EA 25
403 M5010 EARTH ROD EA 4
404 000 5589 BEARING CLUTCH EA 5
405 00 14719 RIGHT REAR BRAKE KIT EA 2
406 00 36724 WINDSCREEN ( WINDSHEILD) EA 11
407 000 5176 BLADE WINDSHIELD WIPER EA 11
408 00 37794 TIER,PNEU205/80R16 6 PLAY MICH XZL EA 141
409 00 14901 ENGINE , DISEL , PEUGEOT XUD90TF,1,905L EA 8
410 00 15173 STARTER EA 6
411 00 15177 ALTERNATOR , ENGINE EA 8
412 0 510602 SCREW EA 3
413 0 530607 WASHER EA 3
414 0 530802 WASHER EA 2
415 00 6389 FUSE 15 AMP EA 20
416 00 50725 BATTERY , STORAGE, 12 V - 60 AH EA 14
417 000 6483 HEADLIGHT EA 2
418 00 37770 FUEL LEVEL INDICATOR EA 3
419 H13413 GRILL,PROTECTION EA 15
420 N107850B TRANSMISSION ASSY EA 2
421 H119000 TRANSFER GASE ASSY EA 2
422 N101022S CHAMNER AIR, EA 36
423 F103009D HOUSING & TUBE, LH FRONT EA 2
424 K102340 SERVICE BREAK ASSY EA 2
425 G116181 LOCK-CONTROL.DOOR ,RH EA 9
426 N117528 BLADE,WINDSCREEN EA 171
427 N117701 MIRROR.LESS ARM & MT EA 8
428 H125300D TARPAULIN, REAR TPX EA 9
429 H125300D-1A TARPAULIN, REAR EA 9
430 N118245K RESERVOIR ,PLAS W INSTALLATION KIT EA 20
431 N117717 BRACKET,ANGLE - SUPPORT W CUP ARM UP EA 2
432 H116062B TARPAULIN EA 2
433 B109155H FILTER,FUEL EA 6
434 N109165B FILER FUEL TANK EA 18
435 B109350H PUMP FUEL LIFT EA 9
436 N110302 ALTERNATOR EA 3
437 H111660 SWOTCJ,LIGHT MOVEMEN EA 6
438 H11660C LIGHTSWITCH ASSY EA 6
439 F111002 STARTER MOTOR EA 6
440 F111002A STARTER MOTOR 24V EA 6
441 B106312H PULLET,CRANSKSHIFT AS EA 3
442 F108620 ELT.V EA 6
443 K102395 VALVE EA 3
444 F117051 HANDLE,SLIDING,FOR SOCKET WRENCH EA 5
445 35906SM LOCKWASHER EA 3
446 E107048 SEAL,OIL, EA 9
447 H107270 SEAL,OIL,MANSHAFT B EA 6
448 H116082 RUBBER,STRIP WS FRAME PACKING EA 18
449 F119847S SEAL OIL DRIVEN SHAFT EA 15
450 N113478 BRACKET,POLICE PLATE EA 12
451 F118706 STRAP , JERRY CAN FASTERNING-SUPPORT EA 5
452 F111655 SWITCH,LIGHT EA 11
453 A110663 TERMINAL EA 42
454 A110662 BATTERY NEGATIVE POST EA 8
455 N110337 DIOOE ASSY EA 3
456 F113005A HEADLIGHT EA 17
457 F113027 LENSE,HEADLIGHT & REF EA 20
458 F113407 LAMP,STOP , BLACKOUT EA 3
459 N113005A HEADLIGHT ASSY,LESS BULB EA 11
460 F113410 LAMP,EAR FA TYPE EA 39
461 H110840 GAGE AIR PRESSURE EA 3
462 F110696A BATTERY ACID,TROPICALIZED,1LI/CO EA 3
463 F118710 JERRYCAN-20LITERS EA 11
464 G 11702 panel,transmission access EA 2
465 G12100102 glass,window EA 6
466 S082902 plate,front belly EA 2
467 S083002 PLATE REAR BELLY EA 2
468 S301102 BRACKET,TRAK PIVOT EA 3
469 S303302 PLATE EA 3
470 S300302 BRACKET,TRAK PIVOT EA 3
471 S300102 SUB FRAME EA 2
472 S303202 PLATE RETANINING EA 3
473 D8NN-7550-AA DISC ASSY EA 9
474 RC103051/1M3032 ACTUATOR BASE,PTO EA 2
475 S300702 TRACK PLATE EA 57
476 S302502 LINK EA 228
477 S302602 LINK EA 228
478 S302902 BUSHING EA 114
479 S302702 BUSHING EA 114
480 S302802 PIN EA 114
481 S300902 ROLLER,FLANGE EA 8
482 S055102 WHEEL ,ASSY DOOR CAB EA 12
483 S068202 LINK 680 MM EA 5
484 S083102 LINK 105 MM EA 3
485 G020302 LOCK ASSY, DOOR EA 5
486 G022002 GUARD ASSY,LIGHT EA 3
487 G022402 GUARD ASSY,LIGHTS EA 3
488 6F2664-C CAP,-PADIATORFILLER EA 8
489 RC100201/20019 BELT.DRIVE EA 12
490 930-B PUSH PULLER LEGS SET EA 3
491 G104102 SCREW EA 18
492 G104202 BOLT EA 12
493 S114402 BOLT EA 6
494 S110602 BOLT EA 30
495 S300402 BOLT EA 6
496 D301202 BOLT EA 3
497 S114202 BOLT EA 24
498 S114602 BOLT EA 6
499 G156102 WASHER EA 12
500 G151102 WASHER EA 24
501 G155702 WASHER EA 12
502 G148302 NUT EA 12
503 G150702 WASHER EA 60
504 G150202 WASHER EA 12
505 S149002 NUT EA 24
506 S148902 NUT EA 30
507 S301302 NUT EA 3
508 0 156502 WASHER EA 6
509 S302202 NUT EA 24
510 S080702 PIN EA 6
511 S080802 LYNCH PIN EA 6
512 S080502 LYNCH PIN EA 6
513 E2NN-5C250-BA GASKET,EXHAUST MANFOLD EA 2
514 G025502 SEAL,CAP DOOR EA 2
515 S055502 BRACKET,MOUNTING EA 5
516 G022302 LIGHT ASSY REAR EA 3
517 81AG-13466-AA TURN LIGHT ,12V,21W,SC WRM EA 6
rendeep
Re: Need URGENT Military Parts
Postby newview on Mon Dec 21, 2015 2:30 pm
Newview Hardware Solutions (NVHS)
We are Defense / Military & security consultants and registered dealers by the Ministry of Defense.
We are experts in Government, Defense / Military, and Security Industries, as well as proven executive leaders in contracting, government procurement policies and practices.
We are also providing Strategic programs Reviews, Assessment & Advisory Services, as well as Proposal Assistance & Partner Selection.
We operate in different countries, well connected to militaries and private companies around the world, with sales representation in many countries.
We are always keeping our door open for new partners to work with.
Availability :
Aviation - Militry and Civil Air Crafts - Platform, Flight services and MRO.
Air Crafts available -
> Douglas A-4 & TA-4 Skyhawk
> McDonnell Douglas F-4 Phantom
> General Dynamics F-16A/B
> Bell AH-1 Cobra
> Fouga Magister
> Boeing 737-700
> Lockheed C-130 Hercules
> Eurocopter AS565 Panther
> Eurocopter AS365 Dauphin
Special Developments -
Unmanned attack A/C
Unmanned attack Boat
Best Regards,
Ran Alon, CEO
Mobile +972-54-2100088
Fax +972-77-3180020
ran@newview-hs.com
NewView Hardware Solutions
www.nhscorp.com
newview
Return to Government and Defense
Users browsing this forum: No registered users and 5 guests
cron
