NEED REUIREMENTS
NEED REUIREMENTS
Postby LINDA HARRELL on Tue Aug 02, 2011 11:41 am
Qty MFG P/N Description MFG
9600 MGA-86563-TR1G MMIC AMP. 0.5-6GHZ TAPE&REEL AGILENT TECHNOLOGIES
600 RC422-152-221-4100 CONN RECT RECEPT 152 SKT 4 ROWS, AIRBORN INC
600 RC422-152-231-4200 CONN RECT RECEPT 152 SKT 4 ROWS, AIRBORN INC
600 RC442-152-321-4100 CONN RECT RECEP PCB SIZE-152, PRESS-FIT, AIRBORN INC
600 EP2AGX45DF29I5 IC ARRIA II GX FPGA ALTERA CORP
1200 EP3C25F324I7 IC CYCLONE III FPGA 39600 CELL ALTERA CORP
600 EPCS128SI16N IC FLASH MEMORY 128MBIT ALTERA CORP
1200 EPCS64SI16N IC MEMORY FLASH 64-MBIT ALTERA CORP
600 EPM7256AEFI100-7 IC MEMORY EPLD ALTERA CORP
1200 AD780BR-REEL7 IC LINEAR REFERENCE VOLTAGE 2.5V OR ANALOG DEVICES
1200 AD7928BRU-REEL IC ADC 12-BIT 8 CHANNEL T&R ANALOG DEVICES
9600 AD9235BRURL7-65 IC A/D CONVERTER 12-BIT T&R ANALOG DEVICES
9600 AD9954YSV-REEL7 IC DIRECT DIGITAL SYNTHESIZER 400MSP T&R ANALOG DEVICES
9600 HSMS-2815-TR1G DIODE RF SCHOTTKY UNCONNECTED PAIR T&R AVAGO TECHNOLOGIES
9600 AQ12EM0R7BAJME/250V CHIP CAP .7PF +/-0.1PF 150VOLT 55X55 AVX KYOCERA LTD
48000 AQ12EM150JAJME/250V CHIP CAP 15PF 5% 150VOLT 55X55 PORCE AVX KYOCERA LTD
9600 AQ12EM3R0BAJME/250V CHIP CAP 3.0PF +/-0.1PF 150VOLT 55X5 AVX KYOCERA LTD
9600 AQ12EM4R7BAJME/250V CHIP CAP 4.7PF +/-0.1PF 150VOLT 55X5 AVX KYOCERA LTD
79200 TACR106K010RTA CHIP CAP 10UF 10% 10VOLT 2X1.35MM TA AVX KYOCERA LTD
15600 TPSC107K010R0100 CHIP CAP 100UF 10% 10V TANTAL T&R AVX KYOCERA LTD
19200 742C163220JP CHIP ARRAY 8-RES 22-OHM 5% 16PINS T&R CTS CORPORATION
7200 IHLP2525CZ-01-1.0UH 20% HIGH CURRENT INDUCTOR 1UH 20% DALE ELECTRONICS INC
1200 74LCX244MTCX IC BUFFER/LINE DRIVER T&R FAIRCHILD SEMICONDUCTOR
9600 HMC326MS8GETR MMIC GAAS DRIVER AMP. 3.0-4.5GHZ T&R HITTITE MICROWAVE CORPORATION
600 HMC468LP3ETR MMIC GAAS 3BIT DIG. ATT. 1DB DC-6GHZ T&R HITTITE MICROWAVE CORPORATION
600 ISL6123IRZA IC POWER SEQUENCING CONTROLLER INTERSIL CORP
269400 C0402C100C5GACTU CHIP CAP 10PF +-0.25PF 50V C0G T&R KEMET ELECTRONICS S A
19200 C0603C180G5GACTU CHIP CAP 18PF 2% 50V C0G T&R KEMET ELECTRONICS S A
40800 C0603C220G5GACTU CHIP CAP 22PF 2% 50V C0G T&R KEMET ELECTRONICS S A
19200 C0603C470G5GACTU CHIP CAP 47PF 2% 50V COG T&R KEMET ELECTRONICS S A
37800 C0603C680G5GACTU CHIP CAP 68PF 2% 50V C0G T&R KEMET ELECTRONICS S A
33600 T491A106K010AH CHIP CAP 10UF 10% 10V TANTAL T&R KEMET ELECTRONICS S A
9600 T491C476K010AH CHIP CAP 47UF 10% 10V TANTAL T&R KEMET ELECTRONICS S A
19200 LT1175IS8_TRPBF‏ IC VOLT. REG. NEG. ADJ. T&R LINEAR TECHNOLOGY CORP
1800 LTM4608AIV_PBF DC-DC 8 AMP LINEAR TECHNOLOGY CORP
9600 1093H504-001 SPECIFICATION FOR MULTI LAYAR BAND PASS FILTER 3050-3500 MHZ MAGLAYER
9600 MAX15024AATB-PLUS-T IC HIGH SINK/SOURCE CURRENT DRIVER T&R MAXIM INTEGRATED PRODUCTS, INC
4800 MAX8557ETE-PLUS-T IC VOLTAGE REGULATOR ADJ. 4A T&R MAXIM INTEGRATED PRODUCTS, INC
9600 MIC4451YMTR IC MOSFET DRIVER T&R MICREL
9600 ADT2-1T-1P-PLUS RF TRANSFORMER 8-600MHZ MINI-CIRCUITS LABORATORY
19800 HFCN-2700(PLUS)-TR CHIP CERAMIC HIGH PASS FILTER T&R MINI-CIRCUITS LABORATORY
9600 LFCN-5000-PLUS CHIP CERAMIC LOW PASS FILTER DC-5000MHZ MINI-CIRCUITS LABORATORY
48000 M3SWA-2-50DR-PLUS SWITCH DC-4.5GHZ SPDT MINI-CIRCUITS LABORATORY
7800 SCN-2-27(PLUS)-TR CHIP P. SPLITTER 2-WAY 2225-2700MHZ T&R MINI-CIRCUITS LABORATORY
9000 SCN-2-49-1(PLUS)-TR CHIP P. SPLITTER 2-WAY 4400-4900MHZ T&R MINI-CIRCUITS LABORATORY
9600 TC1-1-43-PLUS RF TRANSFORMER 50 OHM 650-4000MHZ MINI-CIRCUITS LABORATORY
19200 TC1-1T-PLUS TRANSFORMER 0.4-500MHZ 0.25W MINI-CIRCUITS LABORATORY
9600 TC16-161T-PLUS TRANSFORMER RF 0.6-160MHZ SMT MINI-CIRCUITS LABORATORY
125400 NFL18ST507X1C3D CHIP FILTER EMI T&R MURATA ERIE NORTH AMERICA INC.
48000 BLM15EG221SN1D CHIP FERRITE BEAD EMI FILTER 220-OHM T&R MURATA MANUFACTURING CO. LTD
12000 GRM32ER61C476KE15L CHIP CAP 47UF 10% 16V X5R T&R MURATA MANUFACTURING CO. LTD
32400 NFL18ST207X1C3D CHIP EMI FILTER T&R MURATA MANUFACTURING CO. LTD
9600 MC100EP11DTR2G IC ECL 1:2 DIFF. FANOUT BUFFER T&R ON SEMICONDUCTOR
11400 MC100EPT21DTR2G IC DIFF LVPECL TO LVTTL TRANSLATOR T&R ON SEMICONDUCTOR
600 MC100EPT22DTG IC DUAL LVTTL/LVCMOS - LVPECL TRANSLATOR ON SEMICONDUCTOR
3000 MC100LVEP14DTG IC 1:5 ECL/PECL/HSTL CLOCK DRIVER PB-FRE ON SEMICONDUCTOR
19200 R222.508.740 MALE STRAIGHT RECEPTACLE FOR PCB T&R RADIALL
4200 R223.424.800 CONN RF MMBX PLUG RECP SOLDER CNT GO RADIALL
9600 1093H699-002 FILTER PC BLANK REMTEC
600 SFM-115-L2-S-D-A-K-TR CONN RECTANGULAR SFM SAMTEC
10200 SBB-3089Z MMIC INGAP/GAAS HBT AMP. 0.05-6GHZ T&R SIRENZA MICRODEVICES, INC
1200 SBB-5089Z MMIC INGAP HBT AMP. 0.05-6GHZ T&R SIRENZA MICRODEVICES, INC
12000 SGA-2286Z MMIC SI-GE HBT AMP. DC-5.0GHZ T&R SIRENZA MICRODEVICES, INC
141000 MI0603J601R-10 EMI FERRITE CHIP BEAD STEWARD
19200 TA0375A‏ SAW FILTER 1330MHZ T&R TAI-SAW TECHNOLOGY LTD
10800 TA0760A SAW FILTER 2610MHZ TAI-SAW TECHNOLOGY LTD
9600 C4532X7R1E226MT CHIP CAP 22UF 20% 25V X7R T&R TDK ELECTRONICS CO. LTD.
9600 THS4509RGTRG4‏ IC WIDEBAND LOW NOISE DIF. AMPLIFIER T&R TEXAS INSTRUMENTS INC
9600 SI5515DC-T1-E3 TRANSISTOR MOSFET COMPLEMENTARY 20V T&R VISHAY - SILICONIX
19200 SI7501DN-T1-E3 TRANSISTOR MOSFET COMPLEMENTARY 30V T&R VISHAY - SILICONIX
28800 594D337X9016R2T CHIP CAP 330UF 10% 16V TANTALUM T&R VISHAY SPRAGUE
600 595D107X9016D4 CHIP CAP 100UF 10% 16VOLT 170X110 TA VISHAY SPRAGUE
LINDA HARRELL
Return to Wanted
Users browsing this forum: No registered users and 6 guests
